Old 02-01-2016, 09:10 PM   #10
jaykay
jaykay's Avatar
Very much appreciated, the view helped a lot! I like your 986 render design lines perhaps just as much as the real shape...very tastefully done!
Yes I do like to push the envelope a bit.... as you know. Thanks for the thoughts and info!
See above note Jay... in a meantime:
GTCollection.com - Turismo Series Arctic Silver
Jay mate, not in an ideal position to toast those for you right away but will get them done. I'll get the 3 series lined up, not in Iguana green however. That green rendering belongs to a member here btw (sent you his youtube channel by pm)
RE dual-projectors. If one day I feel that there is a strong demand for dual-projectors I might consider throwing the required R&D and time into this. Atm you are the second guy who asked for this. And as you've already guessed, it would indeed need a serious redesign of the stock headlight. The Bi-Xenon Projectors you see now are designed with an emphasis on simplicity and really, that what works for the majority. Effective, safe, lightweight, easy-to-install, what else... ah yes; reasonably priced (important).
ps: if you want a guesstimate for a quality & functional quad-xenon, by all means feel free to PM - I'll make those for you with passion. However something tells me you'll change your mind as fast as your idea came up +$$+
986 00S
