Old 02-01-2016, 08:25 PM   #3
ksjohn
ksjohn's Avatar
In looking at the transmission diagrams, it looks like there is a bushing for the shaft that can only be replaced if you pull the tail housing and replace from the inside. And the seal is replaced from the outside.
Is this correct?
Is it normal for the bushing to wear out and need to be replaced or is it more typical that only the seal has fails and needs to be replaced?
ksjohn is offline   Reply With Quote
