Old 02-01-2016, 06:52 PM   #9
eomak
Looks good. Question. I just cleaned my throdle body and started cleaning like you with light water and degreaser the outside's of engine. When i took off the main air plastic tube that goes to the throdlebody from the airbox. Right below,i guess where the engine meets the transmission. You can see on the top of the block a little crack that i can see into i guess would be the flywheel or clutch?This normal? Does not look damaged but looks like it could have or should have a rubber capping or cover on it? I can see water/dirt easily getting in there and gumming it up over time.Guess a picture of it would help. So basicly i stopped washing in there. You would think engine/trans blocks are fully case/sealed no?
eomak is offline   Reply With Quote
