Old 01-29-2016, 08:27 PM   #12
jdlmodelt
Originally Posted by epapp View Post
Did you check that there is a spark plug in every cylinder?
clean or replace your spark plugs and try starting again if you have spark. My engine is perfectly healthy and I've flooded it and you would have thought it had zero compression. I had to put my gas pedal to the floor and crank until it started firing.
