Old 01-24-2016, 06:31 PM   #14
PorscheFan5
Okay, was able to finish up the installation of the pump and wiring. Some pics attached.
I am taking the '12V Switched' from the fuse box D4 which is an unused spot. I read somewhere on this forum that one can take 12V Switched from there. Had to do some cutting etc to the side of the fuse box but it worked out. I was quite happy with my work... Routed the wire inside and above the steering column to bring it to the center console from where I have made a hole and added a plastic fitting to take it out from there. I am going to need 12V switched in many places and am thinking I will put a bus bar somewhere...
I am also thinking of changing the allen-head bolt, that goes on the pressure plate that keeps the pressure and return line pressed in, to a hex head bolt and be done with it once and for all...
Hope this helps someone else doing the project.
PorscheFan5 is offline   Reply With Quote
