Thread: The unlucky 1%
Old 01-18-2016, 11:03 AM   #11
mikefocke
There is more than a bit of economics that comes into play when choosing a IMS bearing kit to use unless you are super rich, are blindly loyal to one producer or are unerringly convinced of the logic behind the marketing justification for some kit. How much to spend is really an important element in most people's decision.
Just within the LN/Flat6 line I'd describe the three kits for the 2000-2004 single row engines this way:
The Solution - Appropriate if you are in love with the car, are going to keep it forever, and are going to spend about $12k to $25k doing other upgrades to parts that have become known as weak spots in the engine. This bearing is similar to what is on the other end of the IMS shaft and we never hear of those failing. 100s installed. Highest priced.
The IMS Pro - the dual ceramic bearings into a single bearing space kit is intermediate in cost, not as many installed to prove their true longevity but a good reputation. Appropriate if you are going to keep on top of any issues, want to keep the car for another 5-7 years and you'll be doing lots of preventative maintenance as you can to keep it running smoothly. 100s installed.
The LN single row ceramic bearing kit - lowest in cost, good for 50k+ miles but probably needs to be replaced at some point if the car hasn't crashed or failed by then for one of the other 29 reasons known to bring engines down in the M96 line. 10k ++ installed. Longest installed in largest quantity so a well known reputation.
Outside the LN line, there are other approaches that use lots of different materials, lubrication methods, etc. Lots of different costs too.
How much any of these are tested before being marketed I'll leave to your due diligence.
No matter what you choose, the condition of the engine prior to the replacement of the IMS is a major determinant in the longevity of your replacement. Dirt grinds away at moving parts. Metal flakes grind expensively and often fatally.
And the skill of the installer matters too. Choose your mechanic before you choose your kit.
