Old 01-16-2016, 01:20 PM   #7
boxster
Hi boxster,
is you spare key a fob key? If not, please hold the transmitter (glas capsule) beside the key and try to start the car. If it doesn't start the transmitter will not be recognized by the alarm system and might not work for you car and you won't get it startet if you loose your fob key.
If your spare key is a fob key, just try to start the car with it.
Regards, Markus
Yes its a fob. As I said, I can start the car no problem with the spare key, I obviously can't lock it with the fob, I have to lock it manually, but as I just want it as a safety net just in case I lose the main key, then its good to know that I can turn off the alarm by putting the key in the ignition. I don't need to spend money on a spare key since I have one that I can work with.
boxster is offline   Reply With Quote
