Old 01-09-2016, 08:40 AM   #5
Ricardo1992
Originally Posted by Chuck W. View Post
I had an issue with a coolant leak awhile back. It ended up being a faulty coolant cap. I had the original one where the part number ended in .01. I bought the newest, ending in .04, and all was good. This is fairly common.
Here is the drainage tube that the coolant will drain out of.
Thank you for this! Turned out this was exactly the issue. New coolant lid fitted, problem solved. Now new problem has arisen...will the faults ever stop!?!?
Ricardo1992 is offline   Reply With Quote
