Old 01-07-2016, 05:44 AM   #16
itsnotanova
Harbor Freight has those ball joint separators too. Be careful using them because they can mess up the end of the treads if the ball joint is in tight. It's best to loosen the nut all the way to the end of the treads before using the separator. Break the ball joint loose and then finish removing the nut.
Woody
