Old 01-06-2016, 05:19 PM   #1
JEDD
Originally Posted by stelan View Post
I think you toasted your ignition switch, the only link between amp wires and the actual starting of the car would be the ignition switch, If I'm not mistaken when the inmobilizer is bad or not present the car would still crank but not start (maybe I'm wrong) but I would check the ignition switch, the contacts inside the switch are quite delicate and the little springs inside get burned easy with a short like cutting wires with the battery connected
That would be great. I'll keep my fingers crossed when I check it.
JEDD is offline   Reply With Quote
