Old 01-06-2016, 11:26 AM   #2
911monty
911monty's Avatar
TJ; First do whatever you can to prevent water getting into the car and especially the driver side. If the module under the seat gets wet you will have a bigger problem!
The strip in your question is not really THE problem, It is adding to your problem though. In your picture it appears to me that you are missing the foam drip pan. If this is missing then this is your actual problem. Please take a picture of the area under the top and then post this question in the General discussion area, you will get a lot more responses.
Link to discussion of the opposite side: http://986forum.com/forums/general-discussions/36196-water-drip-pan-986-under-hood.html?highlight=foam+drip+pan
PS Welcome to the Forum, Sorry it had to be this way.
