Old 01-05-2016, 09:32 AM   #1
Luckyed
Luckyed
Luckyed's Avatar
Originally Posted by nicecar View Post
My upper and lower control arms on the front of my 02 S need replaced. Is this something that is fairly easy to do? I have tools jacks etc. If it was wheel bearings or coolant tank I would be more likely to let the indy do it from taking the advice from many on this forum. The procedure does not look too difficult, however alot of tricks are omitted from the instructions on Pelican. IE... putting the wheel under load for aligning the holes properly. Also on the instruction guide subject is the Bentley the way to go if you were to only have 1 choice? Thanks in advance.
Where are you in Florida?
I need to do the rear control arms of my 2001.
If the cars aren't too far apart, perhaps we could knock out both one afternoon? +
Just a thought.....
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
