Old 01-03-2016, 03:13 PM   #2
Sideways Steve
Nice! Looks so much better
What tools/method did you use?
I used the dremel with an 8mm rotary cutter and a multi cutting attachment with depth adjustment set to around 1.2MM.
Then I used a mouse sander with 60 grit to do a first smoothing working my way down to finer grit before a Polish with rubbing compound then my das 6.
Once it looked smooth enough I lacquered them and gave them another flat and Polish.
They could probably do with another coat of lacquer and polished again but I ran out of time!
Sideways Steve is offline   Reply With Quote
