Old 12-31-2015, 06:07 AM   #20
TrumpyAl
Thanks for checking in. I'm standing here next to the car reading my multimeter's manual to understand if it can give me a millisecond reading on the injectors, or just a duty cycle.
Today I confirmed that all the coils are firing across a 2cm gap. I confirmed one side of the car that this is the case no matter which connector I plug the coil into. So I'm confident that it has spark on all 6 cylinders.
I'm toying with the idea of taking off the manifold to inspect it, as well as to hopefully be able to see a valve moving within the inlet port which I can hopefully use to check the timing of the cams. I doesn't look easy though...
And have also been doing a job that no one should ever have to do...
And also derived a bizarre amount of satisfaction detailing one particular spot on the car.
I received the decals for my calipers so that's now waiting for me to get time.
Here she sits. Still!
p.s. 2016 is 75 minutes old here - HAPPY NEW YEAR!
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
