Old 12-27-2015, 05:06 AM   #1
BoxsterSteve
still plays with cars...
BoxsterSteve's Avatar
It seems you have started already!
As far as determining engine health, cut open the oil filter to check for metal debris, and have a local Indy check cam deviations with a Durametric.
If You don't find anything scary, start on the usual deferred maintenance items; brake fluid, coolant flush, trans fluid replacement, clean rads, oil change, serpentine belt and plugs. Check CV boots for tears if it's a stick too as they get more abuse on an S model than a base.
I have done all this maintenance on mine since buying it except the IMSR and the CV boots.
They really aren't that hard to work on and you get to save $$ on labour too.
Congratulations and have fun with that Boxster.
Six speed 2000 Boxster S
