Old 12-16-2015, 03:16 PM   #2
rah rah 986
1998 Boxster
I replaced the front bearings last week on my Honda Odyssey. Both hubs came off with the inner race, just like yours. I found a tip that suggested to use a dermal tool with a metal cutting wheel and make a cut across the race about an eighth of an inch deep, in two or three places. Try to cut as deep as you can without cutting through to the hub. Once you have scored the race, take a chisel, setting it into the groove that you have cut. A couple good wacks with a hammer will break it through completely. In my case, one groove was enough to loosen the bearing enough to slide it off. If necessary, you may have to cut a second or third groove. This technique was easy and worked like a charm.
rah rah 986 is offline   Reply With Quote
