Old 12-15-2015, 01:47 PM   #12
BYprodriver
BYprodriver's Avatar
I would replace the sump plate with a good used one & not do any racing. I have one I could sell you, but it may not get there til after Christmas. Permatex grey ultra seal works great for the sump plate only. The metal doesn't look bad. I would reassemble & check the new oil filter every 100 miles til 3,000 miles, then change & get a oil sample analyzed.
You should also get the cam timing deviation tested A.S.A.P. If the vario-cam solenoid chain wear pads have never been replaced, they should be done A.S.A.P. that's the source of most of the plastic chunks!
