The timer depends on how long the computer thinks it will take for enough oil to get down in the sump to get an accurate reading.
If the car is cold, 5-6 seconds to think. If you take a long drive and turn it off and then immediately turn the key back to accessory mode, the timer starts at 10 minutes. Those are the extremes, and it is adaptive between.
Not starting is over my head. Good luck!
