Old 12-11-2015, 04:27 AM   #1
morgal48
morgal48's Avatar
Just replaced both door pocket lids with new ones. The little holes in the lid part of the hinge made things difficult. To reinstall I put the front pin in, then held the lid as near to the closed position as possible, keeping tension on the spring so it didn't come out of the little hole on the lid. Be sure that the coiled part of the spring is down. I used a small screwdriver to push the end of the rear pin in place. It took several tries. I don't think it's possible to see what you're doing because of the design - if you hold the lid up, you may not be able to force the pin holes into alignment. Be patient.
2000 Boxster S
2010 Volvo XC60
2011 GMC Denali HD 6.6L (sold)
2008 Cayenne S (sold)
1989 Targa (sold)
morgal48 is offline   Reply With Quote
