Old 12-10-2015, 05:17 PM   #2
grc0456
2003 Base 5-speed
grc0456's Avatar
Originally Posted by Spinnaker View Post
After I removed the paint from the driver's side cover on my car, and had the same problem with reinstalling it. Finally figured out that by using a small nail as a dummy pin to hold the spring in place worked. You push the dummy pin out with the regular pin when you install it and the spring stays in place.
Hmmmm....interesting. But I guess I'm still not sure I understand without more detail sor pics. I see where the spring hooks on to the post in the rear, but do you have to pull it over the nail/pin? I'll try to fiddle with it this weekend. Ah the life of DIY - it's never as easy as it seems!
