Old 12-10-2015, 05:01 PM   #1
jim_hoyland
jim_hoyland's Avatar
Having had the AOS go on mine I would definitely have that replaced proactively if it is suspect as the results can be dire if you are unlucky.
I'll second JD's comments.
Done ! Went with the improved OEM AOS . Thanks for the advice on this, I might have deferred the maintenance......
jim_hoyland is offline   Reply With Quote
