Old 05-30-2006, 03:18 PM   #1
MNBoxster
Hi,
I suspect you've put your finger on a number of the issues. Worn Tires will tend to break away much easier/sooner than a newer set. Also, you have your tires waay too inflated, try 5-6lbs. less.
And being less experienced, you may not be able to feel the Car before it breaks away, but that's OK. Just stick with it and try to evaluate how the Car feels and see if you can keep it from the edge. The key to great Auto-Xing is SMOOTHNESS over speed, being unsmooth costs you more speed than you realize.
In the beginning, concentrate on Clean Runs, not the Clock. Your Times will improve naturally as you gain experience. Try to learn from each run and adjust accordingly. Good Luck!...
Happy Motoring!... Jim'99
