Old 12-03-2015, 08:55 PM   #4
Trinamo
Nutier than squirel turds
Originally Posted by Steve Tinker View Post
Everything being equal and you have installed the rear strut correctly (and there's not a lot to get wrong on installation) the only other part than affect ride height is spring length. Did you measure old vs new struts?
Remember that if you removed / loosened the lower control arm connecting the hub to the chassis, the control arm must be loaded (weight of car sitting on its wheels) before tightening the retaining bolts.
I'm back. I went back to the car to fix this error and I'm having a brain fart. I'm now not sure of which retaining bolts you're talking about. I removed the strut by removing the caliper, axle at the transmission only and both eccentrics to allow the assembly to swing down and forward to have the clearance to remove the strut assembly. I marked the positions on the eccentrics before disassembly and placed them back perfectly afterwards.
Trinamo is offline   Reply With Quote
