Originally Posted by MNBoxster
Hi,
It's a little hard to diagnose long-distance, but the retaining Pin should not require any encouragement, perhaps this is the source of the Pads sticking.
Did you use some lube on the Pads to allow them to slide easily?
Also, did you compare all the new parts with the old?
Happy Motoring!... Jim'99
Hi Jim,
Thanks for the heads up on using the file.... I'll pick one up.
I believe it is the source for the pads sticking.....I'll take the file to the pad (hole the pins slides through) this weekend.
The back of the pads are thoroughly lubed with anti-squeel paste while the cotter pin, and large pin are lubed with anti sieze paste.
KRZ
