Both of my 2002's halogens are yellowed, pitted and have burned spots on the interior lenses. So, I'm looking to replace them and would prefer to install Litronics, if it's feasible.
But this comment casts some doubt on it:
Originally Posted by Nine8Six
Lits, without the leveling sensors, are perfectly fine if they are meant for the low beam alone (e.g. city cars). If you are able to manually adjust them to the recommended height/aim they shouldn't blind incoming traffic. The high beam won't work indeed but still it gives the driver the impression that it does. Intensity doubles... and that seems to work for some.
Do the Litronic high beams work without the leveling modules or not? Sounds like they illuminate, so you get twice the output. Are the high beams not aimed higher. Does the rotation of the low beams give the long-distance illumination?
Thanks for any clarification.
