Old 11-27-2015, 08:49 AM   #1
brewerbry
TS bolts
As mentioned previously in other threads, do yourself a favor and do not use the hardware that comes with the TS kit - they are low grade bolts and nuts. I broke 2 during installation - go to home depot and get higher grade bolts so the heads or shaft does not break when you tighten them. Trust me, it is worth the few dollars and avoid the frustration of broken bolts....
brewerbry is offline   Reply With Quote
