Old 11-27-2015, 06:44 AM   #10
Chuck W.
Chuck W.'s Avatar
Originally Posted by jim_hoyland View Post
I finally got around to installing the switch; there is a problem. Spoiler goes up and down correctly. The light in the switch stays on when the spoiler is up.
But; the switch light does not flash as the spoiler raises, but does flash when the turn signals are used.
Can anyone pinpoint the problem ?
When I first installed mine, all of the lights flashed correctly while raising and lowering and stayed solid while it was up. However, when I installed the 996 cluster I lost the flashing while raising and lowering. It stays on solid while it is up and can still operate the spoiler manually. Based on what a PIA the wires are to deal with I have left it as is. The flashing lights were not that big of a deal. Having the solid light on is more important to me.
You do have an issue if the blinkers are causing the indicator to flash. I would betting a wire is plugged into the wrong slot of the plug.
Originally Posted by Xpit77 View Post
Where did you buy them ?
Spoiler Control Indicator Switch Porsche Carrera Turbo 4S Boxster s 986 996 | eBay
1995 Porsche C4 Cab
