My vacuum line at the white connector broke off. From what I can tell it seems the 1999 Boxster factory unit is a two foot long, one-piece line attached to the white valve. But in the diagram the white valve is listed separately and looks like it may have some kind of a compression fitting to attach to the existing hose? I just need to know if I get the new while valve and can I make the connection to the old hose, or do I need to replace the hose/white valve as an assembly? And I already know the o-ring to the manifold needs to be replaced.
