Old 05-28-2006, 09:38 AM   #12
xclusivecar
Originally Posted by MNBoxster
Hi,
As I understand it, the Filter takes about 0.75 Qts. with it. No, if you open the cannister, only the Oil in it and the Filter will be removed from the system - 0.75 Qts...
Happy Motoring!... Jim'99
Thanks MN...then all that needs to be done is to remove the filter, drain the canister, replace filter, start the car, and then check the level. If more needs to be removed...repeat. If to much removed, just add a little oil at a time until satisfied.
2000 Porsche Boxster S
2007 Lexus RX350
xclusivecar is offline   Reply With Quote
