Old 11-10-2015, 11:44 AM   #1
Ben006
Ben-Auto-Design
Ben006's Avatar
Engine mount inserts ... don't !
Hi !
Today, I decided to finally change my engine mount.
It's not the hardest of job, took 1h20min.
To replace my really really bad mount, I chose the updated 987 mount, and Torque solution insert instead of the OEM stops (the inserts were actually cheaper @ 49$).
Well... don't do the same mistake ! The car is undrivable ! It shakes so much that I wonder how I managed to go back home !
Plus, the vibration foul the knock sensors and the car has no power (no CEL).
The inserts squeeze the mount in the carrier so tight that it's basically a solid mount now
Sure, I got rid of a lot of the play in the shifter, which feels even more solid now and shifts beautifully. But I don't see how you can drive this !
So tomorrow I'll have to take the engine mount out again, and cut/grind the inserts so it fits like the OEM one because the dealership did had any stops in stock ...
Conclusion... for your engine mount, buy OEM !
Ben.
Ben006 is online now   Reply With Quote
