Old 11-08-2015, 09:35 AM   #11
thstone
What do you guys think about allowing 2.7s+lbs into the class? Maybe make them run the 2.7 5 speed too? Might give the 2.5s the advantage on short tracks.
I like that idea better than engine mod's. The slight power difference can be mitigated by a slightly higher minimum weight so the power/weight ratio's are the same.
This also addresses a common compliant where Spec Boxster owners have trouble getting the car/driver down to min weight. If you had a heavy 2.5 car, you could swap in the 2.7 setup and be more competitive at the 2.7 min weight.
