Old 11-02-2015, 03:37 AM   #2
heiwaz
Depending on if your car is a base or S someone can tell you what years and makes of transmissions will fit yours. When you changed flywheel was the time to diagnose and remove the gear box cover and inspect the gears.
Good luck.
My boxster is a S model. I think the problem is inside if differential
heiwaz is offline   Reply With Quote
