Its either spark or fuel. To check for spark remove the little rubber hose that connects to the throttle body behind the throttle plate. At the hole, squirt wd40 into the throttle body at the same time you crank the motor. If the motor sputters and runs for a moment you have spark and the problem is fuel.
If you get no sputter then its a spark problem. Unless you have other ignition related codes, suspect the cps.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
