Thread: ecu swap
Old 10-29-2015, 12:52 PM   #3
boxster
Originally Posted by philou320 View Post
Or you can get a galetto FGTECH V54 and switch the files when you need via the OBD socket
I used to do it, very easy, only 5 minutes, nothing to open
Problem is dont have the original map! Is there anything I could do to "cheat" the test? Its failing on co emissions they should be at around 0.5% and theyre reading about 2%. Is there anything I could temporary do to reduce co emissions for the test?
boxster is offline   Reply With Quote
