Thread: Engine Bay
Old 10-22-2015, 07:16 AM   #2
BYprodriver
BYprodriver's Avatar
You should remove the P/S cap, clean it then reinsert to check fluid level. Looks like all that oil is from P/S reservoir, & when it gets low the pump wears. New P/S pump is expensive & a pain to replace. I recommend using a turkey baster to get as much old Pentosion out & refill with new Pentosion. Then extend the vent hose so it will vent below the engine instead of on it.
