Old 10-17-2015, 07:18 AM   #29
Luv2Box
Luv2Box's Avatar
Originally Posted by Xpit77 View Post
Does anyone have that bit of a lag or faux shift while in 2nd under mild acceleration ? I had my trans serviced and it`s fine. It doesn`t do it under high rpm.
Mine used to do that very occasionally. Remember the ECU for the Tip has fuzzy logic and will shift according to the way you drive the car in "D." It is the reason I don't drive in "D" anymore and use "M" so I can shift when and how I want.
Luv2Box is offline   Reply With Quote
