Thread: Tan oil?
Old 10-06-2015, 11:02 AM   #2
BYprodriver
BYprodriver's Avatar
In addition to finding out where the intermix is happening, you will need to do a full flush and fill of the coolant and probably the oil as well after you have it fixed
To get this started pressure test the coolant system to try & locate where the coolant is entering the oil. Since you have a 2000my good chance you have a cracked head. Now is the time to find which head before disassembling anything. When you remove the water pump you must find the missing impeller pieces!
