Old 09-24-2015, 03:16 PM   #1
JayG
On the slippery slope
JayG's Avatar
Sorry Rex, but you are very wrong
I did pro audio for about 15 years and toured with some of the biggest acts in the world.
A conventional loudspeaker has several parts
Basket (frame)
Magnet
Voicecoil
cone
It is basically an electromagnet that the coil is energized and moves in and out of the magnet. The cone is attached to the voice coil and moves in and out with it. As it moved, it moves air at the frequency that is powering the voice coil. this movement of air is what makes the sound. Low frequencies are physically larger and require more air movement, hence larger speakers. Higher frequencies are smaller and require smaller diaphragms/speakers
The voice coil moves evenly in both directions. On the positive side of the waveform, the speaker moves out and the negative side inward. Connecting the "backwards" will merely make the speaker cone's movement be 1/2 cycle off from one wired the other way. IT DOES NOT CAUSE ANY DAMAGE!!!
It will NEVER destroy a speaker being out of phase with another speaker!! If the voice coil is bottoming out, it is broken or just a crappy design.
All being out of phase can do is lower the audio level you hear as there would be some cancellation, however that is only the case when all of the voice coils are aligned in the same plane. If they are not in the same plane, then to get perfect phasing, you would need to delay the signal to the ones that are further forward to get them timed correctly. This is true regardless of the frequency or volume level or power
Since this is a car and a small one for that matter, it is really impracticable and in reality we are at worst talking about a millisecond or so probably less.
If you are really concerned about getting the front and rear speakers in phase with each other, try it both ways and see if you can actually hear any difference. If you can leave the hooked up the way that sounds best to you.
In fact, having the front and rear out of phase with each other could actually sound better as the time it takes to reach your ear is different for the front and rear speakers.
This is because if both front and rear speakers are pushing at the same time they in effect are going to push into each other and cancel each other out. In reality they probably does not happen as you are not equal distances from each voice coil.
That is why some people want their systems time aligned, which in effect is phase aligning them. That however requires making very small changes to the delay in the signal for each speaker
At the end of the day, you probably can't hear the difference anyway in a car, especially with the top down
I'll say it again.
IN NO WAY WILL HOOKING THEM UP OUT OF PHASE CAUSE ANY DAMAGE!!!! it is physically impossible
2004 996 Targa Tip
Instructor - San Diego region
