Old 05-19-2006, 10:13 AM   #3
savinor
Let's use the inlet on the right. If a hole or slot is cut in that pipe just inside the muffler where the arrow head is, the exhaust gases will flow through the hole then follows the path (4) out the rear. You can't see pipe (4) because it's under the others. That bypasses the entire muffler.
RichS
savinor is offline   Reply With Quote
