Old 09-18-2015, 07:05 AM   #1
boxster6354
boxster6354's Avatar
an easy way to adjust would be to raise top enough so you can access the cable motor in the middle of clam shell near trunk lid (see photo).
whichever side is higher disconnect the opposite cable, then from inside the car using the top switch tap it a couple of times close then reconnect the cable and close all the way. Might have to do this a couple of times to adjust.
boxster6354 is offline   Reply With Quote
