Old 05-18-2006, 02:35 PM   #5
insite
Originally Posted by BobMarley1
I also posted a request over at pbb, for someone to test my car and see if I'm crazy.
you might be crazy... :-)
it's odd for you to have this feeling in a boxster. you may have more than one problem. first, 59K is not that many miles (especially for suspension components to wear to the extent that you'd experience these types of issues). let's pretend that you have TWO issues: a rattle, and a not-so confident driver's experience.
rattle: don't just start replacing parts. where is it coming from? when do you hear it? is the car warm / cold? are you going slow / fast? is it over bumps or in turns? give us as much info as possible.
second: i doubt if anything in your suspension is worn so badly that your car's performance has been reduced to the degree of which you speak. let's start with the logical owner influenced possibility: what kind of tires are on the car?
also, what year is the car? base or 's'? tip or manual?
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
