Old 05-18-2006, 05:57 AM   #14
savinor
Update for Randall
I have finally found the right combination. I cut (2) 3/8" slots in each side of both inlet pipes for a total of (8) slots. That and secondary cat bypass pipes produce the most wonderful sound from my '00 S. A nice deep rumble that sounds like an agressive sports car. Just loud enough but not so loud that it would be a problem on a long trip. The trick is to use the thicher cutting wheel (3/8") after the thin wheel. You can also get these at ACE hardware stores.
Good Luck
savinor is offline   Reply With Quote
