Old 09-13-2015, 05:59 AM   #1
Chuck W.
Chuck W.'s Avatar
Originally Posted by PaulDash View Post
Have the same problem. Durametric says lock sensors in frunk and trunk, both doors, and central console lid work fine. Still, I get the chirp.
It started when I put in an aftermarket Becker radio. Its alarm light flashes when car is locked, but could it be the little cable in the back needs to be grounded (or at +12V)?
There is a ground wire that is attached on the left side of the frame that the radio slides into. Disconnect this wire and you should be good.
Take a look at the right side of the below photo. You will see where the ground wire is attached.
Originally Posted by JRide View Post
I just learned something new. Didn't know the center console lid locks with the remote!
And... it locks the gas lid also.
1995 Porsche C4 Cab
