Thread: overheating
Old 09-11-2015, 05:46 PM   #1
Vanya
Originally Posted by Jamesp View Post
Not normal. Don't drive it like that. First thing, remove front fascia and clean the gap between the AC condensers and the radiators. If that is packed with trash, which is common, run it and see if it is fixed, if not, you've likely a damaged water pump impeller, so check that next. Temp needle should be passing through the low side of the 8.
I already clean the radiators but not the water pump...
How to check the water pump if its damaged?
Vanya is offline   Reply With Quote
