Old 09-10-2015, 12:23 PM   #2
kiyakubuke
Originally Posted by Matchbox01 View Post
Answering my own question, just in case anyone is interested...
These specs are the stock Porsche specs.
M10 Bolt - 48 ft/lbs - Front Sway Bar to Suspension Subframe
M10 Bolt - 48 ft/lbs - Front Sway Bar to Sway Bar End Link
M12 Bolt - 63 ft/lbs - Front Sway Bar End Link to Wheel Upright (pinchbolt)
M8 Bolt - 17 ft/lbs - Rear Sway Bar to Suspension Subframe
M10 Bolt - 48 ft/lbs - Rear Sway Bar to Sway Bar End Link
M12 Bolt - 63 ft/lbs - Rear Sway Bar End Link to Wheel Upright (pinchbolt)
FYI for the stock drop links there is a 3 step torque procedure for the drop link where it mates to the sway bar.
#1 - 37 ft/lbs
#2 - Loosen by 90 Degrees
#3 - Tighten to 48 ft/lbs
I just replaced all 4 of mine. did you have any issues with yours?
kiyakubuke is offline   Reply With Quote
