Thread: Fluid leak?
Old 09-06-2015, 06:47 PM   #10
springer123
Update: The left radiator had a small hole in it. The reason the drop on the floor was brown and slimy was because of rust where the hole was. I had the radiator replaced along with a new water pump, thermostat and all the hoses. The temp gauge is now running about 10 degrees cooler. It was the original pump, thermostat and hoses with 57,000 miles on the odometer. The car is a 1999 so I'm glad I got everything changed.
springer123 is offline   Reply With Quote
