Thread: Dodged a bullet
Old 09-05-2015, 04:07 PM   #1
KevinH1990
KevinH1990's Avatar
I think the issue with the bolts on the water pump is that two of the bolts are longer than the others. If you put a long bolt in a short hole and attempt to tighten it you encounter the problem JayG had. I'm not sure if the DIY guides make that clear.
The trick is to keep track of the bolts and put them back in the same holes you removed them from.
