Could be a coincidence since none of the work you had done should have involved fuel system. So the items I would check that are in the area are the 02 sensors. May have been cracked or wiring disconnected. I'd visually check there. Unfortunately you will need a Durametric or similar to reset the CEL. If no visual issues then get the codes read and someone will be able to help.
