Old 09-02-2015, 11:51 AM   #2
CrisZenithBlue
CrisZenithBlue's Avatar
I would check the sensor in the latch and hand brake. I believe the one on top of the motor and the one behind the shoulder tell the top it's closed or open. I had a car where the shoulder sensor was bad and it kept letting the motor run until the gears inside the transmission came off.
yeah if the issues start when trying to open the top the two sensors you mentioned are most likely the culprit.
my problem is worst than that probably. as soon as i get a chance i'll swap out the micro switch you sent me and will also check the passenger side transmission to make sure the gears are intact then start realigning the mechanism if needed.
CrisZenithBlue is offline   Reply With Quote
