Old 09-01-2015, 04:05 PM   #19
JayG
On the slippery slope
JayG's Avatar
Originally Posted by Deserion View Post
I just did this job Friday night.
Pierburg equals Porsche OE. Pierburg makes the pumps for Porsche. Only difference is the box, the Pierburg I bought even had the Porsche part number cast and stamped into it. Same for the Wahler thermostat, but the Porsche part number casting was ground off of the housing.
Zerex G-05 coolant works well (as it does in all-aluminum Mercedes-Benz engines) if you don't want to shell out $35/gallon for Porsche coolant concentrate.
May as well change the thermo while you're in there since it's right next to the pump and you'll lose coolant anyway. Why do it later?
Avoid any pump with a metal impeller as that can cause engine block damage if/when the bearing goes out, while composite will not do that.
Same thing, I got a Pierburg WP and it has the Porsche part number on stamped on it.
I paid $190 for the WP, $52 for low temp thermo/housing/gasket & $3.50 for the WP gasket, no sales tax and free shippingh @ warehouse33auto.com
2004 996 Targa Tip
Instructor - San Diego region
